Displaying Custom Category Fields
June 14, 2012 12:45pm
  • #1 / Jun 14, 2012 12:45pm
    bgomski
    I’d like to be able to display a categories’ custom fields on a given page.
    I don’t really know what syntax/tags to use and I haven’t had any luck finding in the documentation.
    Anyone have an example of how I might do this?
    Any help would be much appreciated!
  • #2 / Jun 14, 2012 1:03pm
    Rob Allen
    Hi bgomski welcome to the forums
    Is this inside a Channel entry, or when you output a list of categories?
  • #3 / Jun 14, 2012 4:10pm
    bgomski
    Thanks Rob!
    Ideally the category and its custom fields would be placed outside the channel:entries tags. (or at least seem independent of the channel entries loop such that it doesn’t repeat over and over)
    Is that possible?
  • #4 / Jun 14, 2012 5:39pm
    bgomski
    I might be missing a key concept with Expression Engine (im a newbie) so bear with me.
    I approached Custom Category Fields with the idea that I might be able to place these fields in the “header” of a layout on a given page. And with that I could make these fields editable without having to set up a new channel for something the user wouldn’t be updating very often.
    I suppose I could get it done as a channel but I wanted to wrap my head around how to use these Custom Category Fields. So, thought I’d ask.
  • #5 / Jun 15, 2012 5:15am
    Rob Allen
    Assuming you use the standard category tag you can add custom fields inside the tag loop, by simply using the custom field short name:
    {exp:channel:categories channel="mychannel"}
      <h1>{category_name}</h1>
      {if category_description}
        {category_description}
      {cat_custom_field1}
      {cat_custom_field2}
    {/exp:channel:categories}
    The docs are your friend here, see the Category sections at http://ellislab.com/expressionengine/user-guide/modules/channel/index.html for a full list of parameters and variables.
  • #6 / Jun 15, 2012 11:57am
    Shane Eckert
    Hey bgomski,
    I am glad to see that Rob was able to help you out!
    Is there anything else I can help you with?
  • #7 / Jun 15, 2012 4:39pm
    bgomski
    Great, that’s exactly what I was looking for.
    Thanks Rob!
  • #8 / Jun 15, 2012 4:40pm
    Shane Eckert
    Hey bgomski,
    Glad to see that Rob was able to help!
