using “if” conditionals on checkboxes
June 14, 2012 12:34pm
  • #1 / Jun 14, 2012 12:34pm
    77120
    im trying to make a if conditional on a checkbox with multple boxes
    but if theres more then one box selected it doenst work
    {if checkbox == "foo"}
    works
    {if checkbox == "foo, bar"}
    doenst work
    how can i get this to work?
  • #2 / Jun 14, 2012 1:05pm
    Rob Allen
    How many values could your checkbox have?
    Normally I’d use a conditional for each possible value;
    {if checkbox_field == "Yes"}
    Answer yes
    {if checkbox_field == "No"}
    Answer no
    {if checkbox_field == ""}
    Not specified
  • #3 / Jun 14, 2012 1:16pm
    77120
    if two options are checked it must be a different answer than if just one of them is selected
    so with “foo, bar” i meant 2 different options being selected.
    i indeed didnt make that clear 😊
  • #4 / Jun 15, 2012 5:21am
    Rob Allen
    Ok, maybe use the standard tag loop to output the checkbox data:
    {checkbox_field}
        {item}
    {/checkbox_field}
    That would output any value that has been checked.
    Alternatively you could use a conditional to only display certain item values:
    {checkbox_field}
      {if item == "Red"}
      {item}
      {/if]
    {/checkbox_field}
    Docs at http://ellislab.com/expressionengine/user-guide/modules/channel/custom_fields.html#checkbox-fields
  • #5 / Jun 15, 2012 6:09am
    77120
    ah yes thanks that did the trick, more easy then i thought it would be 😊
    i now can use the conditional as {if item == "Red, Blue"}
  • #6 / Jun 15, 2012 6:59am
    Rob Allen
    Not that syntax, but could use a complex conditional:
    {if item == "red" OR item == "blue"}
    {item}
  • #7 / Jun 15, 2012 7:05am
    77120
    hmm it does work with the ,
    and otherwise i think it should be AND
    {if item == "red" AND item == "blue"}
    {item}
    which also works, thanks i will use that
  • #8 / Jun 15, 2012 7:09am
    Rob Allen
    Does it work with comma separated values? Not seen that before 😊
    Good stuff - you could use AND or OR depending what you want to compare.
  • #9 / Jun 15, 2012 11:37am
    Shane Eckert
    Hey 77120,
    I am glad to see that you and Rob were able to resolve your issue.
