CP Home image not found : MSM install
June 11, 2012 11:38am
  • #1 / Jun 11, 2012 11:38am
    Jacob Graf
    I am having an issue with the home icon in the Control Panel coming up as not found while logged in as any user except the Super Admin.
    When I look at the source, the Super Admin is pointing to the full URL for that image, but when logged in as an “Editor”, it is looking to a relative URL for that image. Since this is an MSM install, the image works when logged into the first site, but is broken when logged into the second site.
    My theme URL and Path are both pointing to site1 under site 2’s general preferences.
    Any ideas? Thanks!
  • #2 / Jun 12, 2012 5:25pm
    Shane Eckert
    Hi Jacob,
    Can you compare your configuration settings with the sample below. Just to make sure CP’s are set correctly?
    //CONFIG//
    $config['cp_url'] = "http://engine.dev/admin.php";
    $config['doc_url'] = "http://ellislab.com/expressionengine/user-guide/";
    $config['is_system_on'] = "y";
    $config['allow_extensions'] = "y";
    $config['site_label'] = "Test 23";
    $config['cookie_prefix'] = "";
    $config['multiple_sites_enabled'] = "y";
    index.php and admin.php site 1
    NO CHANGES
    index.php and admin.php site 2
    $system_path = '../system';
    $assign_to_config['site_name']  = 'msm_test';
    $assign_to_config['cp_url'] = 'http://msm.dev/admin.php';
    $assign_to_config['site_url'] = 'http://msm.dev';
    --- admin ---
  • #3 / Jun 13, 2012 12:09pm
    Jacob Graf
    Yes, this is confirmed, but I have since moved the site out of development and into production and everything seems to be working now. It MUST have been a typo SOMEWHERE. Thanks for your help Shane!
  • #4 / Jun 13, 2012 12:10pm
    Shane Eckert
    Hi Jacob Graf,
    Go figure! That has happened to me several times!
