Execute Javascript inside of XTML published article??
June 07, 2012 8:44pm
  • #1 / Jun 07, 2012 8:44pm
    handyman
    As per the title - is it possible to use any sort of wrapper to make a JS call (like adsense) work inside a article published in EE 1.7?
    I already have done do in the TEMPLATES, and have also used “no format” and then HTML and JS pasted in…both work fine. But this is an instance where I want to tag only certain articles to have an ad in the middle of the text - and they are all XHTML plain EE texts.
    To make it clearer, I need to execute the code - for example - in the middle of the “body” piece of an entry.
  • #2 / Jun 08, 2012 5:19pm
    Shane Eckert
    Hey handyman,
    Thank you for posting your question here on the ExpressionEngine forums.
    Can you show me the code you are thinking of using?
    I am not sure it would work in a custom entry field, but let’s see what you got!
