Problems after upgrading to V2.5.1
June 01, 2012 3:09pm
  • #1 / Jun 01, 2012 3:09pm
    Danny Valle
    I upgraded to Version 2.5.1 and and having the following issues:
    1. The upload image button isn’t working from within the New Entry page. It works from the file manager though.
    2. I get this error when I go to “Add-ons > Modules”:  “Unable to load the requested language file: language/english/rte_lang.php”
    Anybody have any ideas as to what may be the issue?
  • #2 / Jun 01, 2012 4:47pm
    Danny Valle
    Ok, I fixed the error on the modules page, was missing that file for some reason.  However, I am having an issue with the upload image button. I have attached an image that shows the upload file interface on the post entry page. It definitely doesn’t belong there, not sure where to start with this.
  • #3 / Jun 02, 2012 8:25pm
    Kurt Deutscher
    This all just sounds like an issue with the /themes/ folder. As if it wasn’t fully backed up and then replaced with all new files. I would make sure you have a full back up of your old /themes/ folder, then delete your current set entirely, and re-upload with fresh ones that came with 2.5.1.
    Also, clear caches once the new /themes/ are in place.
  • #4 / Jun 04, 2012 12:36pm
    Shane Eckert
    Hey Danny Valle,
    I second Kurt’s advice. That’s most likely the culprit!
  • #5 / Jun 05, 2012 1:36am
    Danny Valle
    I replaced the themes folder with the new version entirely, but it didn’t work.  BUT, what I realized what I may have done, is not properly replaced the system folder correctly when upgrading.  Is it possible to run through the upgrade process once again to ensure a proper upgrade?
  • #6 / Jun 05, 2012 10:11am
    Shane Eckert
    Hey Danny,
    Yes, check out this article. You will want to backup first as running the update will update the DB as well.
