Forum broken: throwing Error on Post or Login
May 25, 2012 9:59am
  • #1 / May 25, 2012 9:59am
    C Campbell
    Hi All,
    I have an issue with an installation running EE 1.6.8 and Forum Module 2.1.2.
    Anyone trying to post in the forum is getting the following :
    You don’t have permission to access /index.php/S=bf71c9b333146487189588c930ebf2b2324ca8d1/forums/newtopic/20/ on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    Also attempting to login from the “Login Form - Mini Version” forum template is getting a similar message.
    Any one got a clue what this is about?
    Forum has been running fine for years without a problem??
    thanks
    cc
  • #2 / May 25, 2012 6:09pm
    C Campbell
    As an update to the above I made an 403 error page so I could tell what was going on as it was a missing 403 page that was throwing the 404.
    The 403 error gives this:
    Error Status Code:403
    Referring URL: <a href="http://www.&#91mysite&#93.com/index.php/forums/viewthread/325/">http://www.[mysite].com/index.php/forums/viewthread/325/</a>
    Requested URL: /index.php/forums/newreply/325/
    Also I switched themes to the default forum theme and we are getting the same errors.
    Attempting to login using the embedded “Login Form - Mini” in the forum ‘templates>Login form templates>Login Form -mini’ gives a 403 error:
    Referring URL: <a href="http://www.&#91mysite&#93.com/index.php/forums/">http://www.[mysite].com/index.php/forums/</a>
    We really need some help with this as the forum key to the site.
  • #3 / May 28, 2012 5:41am
    C Campbell
    Update:
    Apparently the host has done a little security hardening on the server…
    Their security logs showed up an ‘issue’ where some of the Forum form posts- login, reply to post etc - where being flagged as an injection attempts as the form post contained the complete URL like http://www.[mysite.com]/index.php ...apparently..
    Hats of to the tech support guy though as he resolved the problem in about 4 mins- much less time than the 4 days is taken me trawling through the code trying to find the issue myself .
    Note to self- when it looks like a hosting, smells like a hosting issues and sounds like a hosting issue issue it is most likely a hosting issue (but not always) 😉
  • #4 / May 29, 2012 11:24am
    Dan Decker
    Hi C,
    Thanks for your question and persistence in the updates!
    Sage advice, my friend 😉
    It looks as though you are all set, but is there anything else I can assist you with?
