Display if custom fields aren't empty.
May 25, 2012 2:48am
Subscribe [4]
  • #1 / May 25, 2012 2:48am
    Jason Varga
    I’d like to display a list of entries depending on whether at least one of three custom fields have been entered.
    {exp:channel:entries
    channel="products"
    category="{category_id}”
      dynamic=“no”
      search:custom_field_1=“not IS_EMPTY”
      search:custom_field_2=“not IS_EMPTY”
      search:custom_field_3=“not IS_EMPTY”}
    This isn’t working because it’s checking that all 3 fields aren’t empty.
    How can I check that at least 1 isn’t empty.
    (In my example, my exp:channel:entries is wrapped with a exp:channel:categories tag. That’s where the category_id is coming from)
    If the answer is to use the query module, could you please give me an example? I’m not so good with SQL 😊
  • #2 / May 25, 2012 9:27am
    Rob Allen
    I’d say that you may need to look to using conditionals inside the channel entries tag instead of using paramaters, eg
      channel=“products”
      category=”{category_id}”
      dynamic=“no”}
    {if custom_field1 != ""}
    Stuff
    {if custom_field2 != ""}
    More stuff
    {if custom_field3 != ""}
    Even more stuff
  • #3 / May 25, 2012 9:40am
    Jason Varga
    Thanks, but I need to be able to use {if count == 1} and {if count == total_results}.
    Unfortunately your solution won’t let me do that accurately.
  • #4 / May 25, 2012 9:51am
    Rob Allen
    You may be able to use advanced conditionals here, by checking if any of the fields has content:
    {if custom_field1 != "" OR custom_field2 != "" OR custom_field3 != ""}
        {if count == "1"}
        Start
        Output content
        End
  • #5 / May 25, 2012 11:53am
    Jason Varga
    Even if you use {count} and {total_results} inside a conditional, they will display the number according to the entries tag as a whole…
    If I have 10 entries, and only 2 match the conditional:
    {total_results} will still be 10, not 2.
    {count} won’t necessarily be 1 and 2.
  • #6 / May 31, 2012 9:52pm
    Jason Varga
    Does anyone else have any advice?
  • #7 / Jun 14, 2012 9:07pm
    Alex Kendrick
    This query, when used with the query module (and modified to have custom_field_id that matches your data) should do the trick for you
    SELECT title, field_id_136, field_id_137, field_id_138
    FROM exp_channel_titles
    JOIN exp_channel_data ON exp_channel_data.entry_id = exp_channel_titles.entry_id
    WHERE field_id_136 != '' OR field_id_137 != '' OR field_id_138 != ''
  • #8 / Jun 15, 2012 3:37am
    willm
    Take a look at Mark Croxton’s Search Fields plugin: https://github.com/croxton/Search_fields
    It allows the same search options as the channel:entries tag, but let’s you set an operator of AND/OR for the conditions. From the docs:
    {exp:search_fields
        search:title="keyword"
        search:custom_field="keyword"
        search:cat_name="keyword"
        operator="OR"
        channel="my_channel"
        parse="inward"}
        {exp:channel:entries entry_id="{search_results}" disable="member_data|categories" dynamic="no" orderby="title" sort="asc" limit="10"}
            <a href="http://{page_url}">{title}</a>
    {/exp:search_fields}
  • #9 / Jun 15, 2012 12:20pm
    Jason Varga
    Thanks for the help everyone, the Search Fields plugin worked perfectly.
    It seems a lot more manageable than using SQL.
