ExpressionEngine Info showing 2.4 as up to date.
May 24, 2012 10:57pm
  • #1 / May 24, 2012 10:57pm
    UltraBob
    I think I may have followed instructions to stop my site from breaking when the Ellis Labs sites had an outage, and I’m assuming that is what has caused this, but my control panel shows 2.4 as the up to date version of EE.  Any ideas about how I would go correct that?
  • #2 / May 25, 2012 5:09pm
    Shane Eckert
    Hello UltraBob,
    You just need to re-enable the version check and I believe you will be back in business.
    Or you can upgrade to 2.5 and be on the latest version.
    Your choice. 😊
  • #3 / May 25, 2012 6:11pm
    UltraBob
    The whole point was that I’m not sure how to renewable the version check.
  • #4 / May 26, 2012 5:54am
    dframpton
    To enable version checking I think you’d set ‘New Version Auto Check’ to yes under General Configuration in the CP.
    However, looking at an install of mine, auto check *is* set to yes but the EE Info panel is saying that I’m also up-to-date (although I’m still on 2.4.0).
  • #5 / May 26, 2012 10:35am
    UltraBob
    Yeah, same here.  When Ellis Lab’s site went down and took their entire EE2 customer base’s control panels with them, I vaguely remember some code being passed around to disable the check.  I was being lazy and hoping someone remembered what it was.  If I haven’t gotten an answer by Monday our time, I’ll have to stop being lazy and either go back and find out what the change I made was or go ahead and run the update which will probably fix the version check issue.
  • #6 / May 30, 2012 3:10pm
    Shane Eckert
    Hello UltraBob,
    dframpton is correct. To enable the check go to Admin->General Configuration and check yes for the New Version Auto Check.
    Feel free to grab 2.5.1, it was released today.
    Is there anything else I can do to help?
  • #7 / May 30, 2012 10:52pm
    UltraBob
    I’m losing faith in my skill with my native tongue. I thought I had indicated that, like dframpton I had the setting correct, but that the issue still existed. Really this is not important enough to have a multi-week support thread open over. Please just close it and I’ll figure it out on my own or upgrade and expect that that will fix the issue.
  • #8 / May 31, 2012 9:48pm
    UltraBob
    Well fancy that, now it is all working and without me having changed anything.
  • #9 / Jun 01, 2012 2:15pm
    Shane Eckert
    Hey UltraBob,
    Thanks for letting us know.
