Weird File Uploading Issue
May 24, 2012 11:25am
  • #1 / May 24, 2012 11:25am
    sebastianjt
    Hello,
    I am having a really weird file uploading problem. I can perfectly upload files on my end as a SuperAdmin, but my content managers, on a different member group can’t. I am sure this member group has all the permissions to upload files to this directory, the director is writable, etc, etc…
    I did all the necessary trouble shooting, suggested here on the user guide:
    Troubleshooting File Upload Issues
    This error is usually caused by insufficient permissions or incorrect configuration:
    - The Upload Directory needs sufficient permissions. On a UNIX type server this usually means “777” permissions are required.
    - The error can also occur if ExpressionEngine could not copy or move the uploaded file from the temporary upload directory, as specified by the server. The upload directory needs appropriate permissions.
    - In Admin > File Upload Preferences, a full server path must be provided in the “Server Path to Upload Directory” preference. This is neither a relative path nor a URL. If the exact path is not known contact the host or server administrator to obtain that information.
    -In some cases this error has been reported due to a trailing slash (/) at the end of the directory name under Admin > File Upload Preferences (or Gallery or Forum Preferences).
    I am using ExpressionEngine v2.4.0.
    Thanks for any help in finding what the problem may be.
    Sebastián Jaramillo T.
  • #2 / May 24, 2012 12:14pm
    Kurt Deutscher
    Try turning off the XSS Filtering. If I recall, EE had a bug/feature like this at one point that could be worked around by turning off the XSS filtering. Supper Admins may not get their uploads filtered, and that can make this issue hard to pin down.
    Admin > Security and Privacy > Security and Session Preferences
    Apply XSS Filtering to uploaded files?
  • #3 / May 25, 2012 10:29am
    sebastianjt
    Hello Kurt,
    Apparently this did the trick. Thanks for your help.
  • #4 / May 25, 2012 11:57am
    Dan Decker
    Hi Sebastian,
    I’m glad to see Kurt was able to get you sorted out.
    Thanks Kurt!
    If you need anything else, just let us know!
