Some upload_preferences not loading
May 17, 2012 8:02pm
  • #1 / May 17, 2012 8:02pm
    Supply
    HI ya,
    I’m having a strange issue where some settings in the upload_preferences config array are not applied.
    I am using the NSM bootstrap for my site config.
    Here is my upload_preferences declaration:
    'upload_preferences' => array(
       array(
        'name'=>'Tiles',
        'server_path'=> NSM_BASEPATH . '/uploads/tiles/',
        'url'=> NSM_SITE_URL . '/uploads/tiles/'
       array(
        'name'=>'Products',
        'server_path'=> NSM_BASEPATH . '/uploads/products/',
        'url'=> NSM_SITE_URL . '/uploads/products/'
       array(
        'name'=>'Files',
        'server_path'=> NSM_BASEPATH . '/uploads/files/',
        'url'=> NSM_SITE_URL . '/uploads/files/'
    in the CP the Products(id 1), Files(id 2) load fine - but Tiles(id 3) is not applied (database value is loaded).
    If I change the order of the array in upload_preferences, then all sorts of stuff goes wrong in the CP. for e.g. both Files & Tiles are labeled as Tiles.
    Is anyone else having issues like this?
    Cheers
  • #2 / May 18, 2012 4:31pm
    Kyle Cotter
    Hi Supply,
    It appears your syntax for the array isn’t complete.
    To set upload paths via config.php, you need to use the following syntax,
    $config['upload_preferences'] = array(
        1 => array(                                                            // ID of upload destination
            'name'        => 'Staging Image Uploads',                          // Display name in control panel
            'server_path' => '/home/user/example.com/staging/images/uploads/', // Server path to upload directory
            'url'         => 'http://staging.example.com/images/uploads/'      // URL of upload directory
    You haven’t passed an ID for the upload destination.
    Hopefully, once you do that, you’ll be up and running.
    So, something like,
            'name'        => 'Products',                          // Display name in control panel
            'server_path' => NSM_BASEPATH . '/uploads/products/', // Server path to upload directory
            'url'         =>  NSM_SITE_URL . '/uploads/products/'      // URL of upload directory
        2 => array(                                                            // ID of upload destination
            'name'        => 'Files',                          // Display name in control panel
            'server_path' => NSM_BASEPATH . '/uploads/files/', // Server path to upload directory
            'url'         => NSM_SITE_URL . '/uploads/files/'      // URL of upload directory
        3 => array(                                                            // ID of upload destination
            'name'        => 'Tiles',                          // Display name in control panel
            'server_path' => NSM_BASEPATH . '/uploads/tiles/', // Server path to upload directory
            'url'         => NSM_SITE_URL . '/uploads/tiles/'      // URL of upload directory
    Let me know if that fixes it.
  • #3 / May 20, 2012 4:40pm
    Supply
    Hi Kyle,
    yes that’s fixed it, cheers.
  • #4 / May 22, 2012 12:08pm
    Kyle Cotter
    Hey Supply,
    Glad I was able to help!
    If you have any more questions, feel free to post again.
