Unauthorized access redirect not working
May 15, 2012 5:30am
  • #1 / May 15, 2012 5:30am
    Pv Ledoux
    since we upgraded to 2.4, the unauthorized templates access are not redirect to the defined location in the CP (see screenshot).
    The problem occurred for every unauthorized templates.
    In all the templates, I have an embedded header called on the first line with the following:
    {if logged_out}
     {redirect="/backoffice/login"}
    Not sure what I’m doing wrong here.
    Regards,
    Pv
  • #2 / May 16, 2012 11:48am
    Dan Decker
    Hi Pv Ledoux,
    Sorry for the trouble you are having here.
    It may be inconsequential, but you shouldn’t need the leading slash in your redirect path.
    {if logged_out}
     {redirect="backoffice/login"}
    But more directly, in 2.4, there is this bug. If you apply the fix or update to 2.5 you should be in good shape.
  • #3 / May 16, 2012 11:57am
    Pv Ledoux
    Hi Dan,
    thanks for your answer. I identify the bug, but couldn’t find it in the bug tracker. Thanks a lot!
    Cheers!
    Pv
  • #4 / May 18, 2012 6:03pm
    Dan Decker
    Hi Pv,
    Fantastic!
    If you need anything else, just let us know.
    Cheers!
