Safecracker + RTE, not working correctly when editing existing Channel Entries
May 11, 2012 5:26am
  • #1 / May 11, 2012 5:26am
    DanL
    I’m using the new RTE to add & edit channel entries via the front-end.
    It appears to work fine when I’m adding a new channel entry, however, when I use the same template to edit an existing channel entry, the WYSIWYG screws up, and displays the raw HTML in the editor window.
    Here’s what I see when adding a new entry:
    Adding a new entry
    Here’s what I get when I open that entry for editing (in WYSIWYG view):
    Editing - WYSIWYG view
    And here’s what it looks like in Code view:
    Edting in code view
    The exact same template is used for adding new & editing existing entries.
    What’s going on?
  • #2 / May 14, 2012 10:53am
    DanL
    Anyone?
  • #3 / May 14, 2012 12:21pm
    Dan Decker
    Hi Dan,
    First of all, let me congratulate you on a fantastic name. I totally approve.
    Second, I didn’t replicate your exact issue, but I did find some bugs.
    In order to get this exactly right, can you tell me a bit more about your situation?
    Were these exiting channel fields that you converted to RTE?
    What was the formatting for the Textareas before conversion? Were the set to None, XHTML, etc.?
    If you convert them back to textareas, what do you see in the Control Panel edit screen? In SafeCracker?
    Can I see your SafeCracker template code?
    We’ve definitely found *some* bugs, I just need your help to determine how many. Thanks!
  • #4 / May 14, 2012 1:28pm
    DanL
    Hey Dan,
    Yes, actually they were previously textarea fields before I updated to EE2.5 (from 2.4).
    Pretty sure the field was set to XHTML.
    If I change the field back to an XHTML textarea, I get the HTML markup in both the CP and Safecracker.
    Sure thing:
    (note that {field:our_people_bio} is the RTE field)
  • #5 / May 15, 2012 9:02am
    DanL
    Just for info, if I create a brand new channel field as an RTE, I get the same problem, so it does not appear to be related to a field’s previous “history”.
  • #6 / May 16, 2012 12:17pm
    DanL
    Any news on this?
    Thinking I’ll just need to cut my losses and ditch RTE in favour of WYGWAM.
  • #7 / May 16, 2012 4:59pm
    Dan Decker
    Hi Dan,
    I’ve brought this up to the Dev team, since I wasn’t able to replicate exactly. They are aware of the issue and are working on it as a bug at the moment.
    Essentially, your content is getting “double encoded”, but the Control Panel compensates for this, where SafeCracker does not.
    There isn’t a fix available right now, however.
  • #8 / May 17, 2012 6:11am
    DanL
    Ok cheers Dan.  WYGWAM it is 😊
  • #9 / May 21, 2012 5:27pm
    Dan Decker
    Hi Dan,
    Thanks for you patience!
    We’ll be making improvements to RTE as time goes on. It is definitely a 1.0 product at this point!
