Revision Author
May 11, 2012 4:23am
  • #1 / May 11, 2012 4:23am
    Jabbler
    I’d like to display “Last Edited by”. I can’t find the tag that can pull the last revision author.
  • #2 / May 11, 2012 8:07am
    Boyink!
    That’s because it doesn’t exist..😉
    Each entry gets an author assigned, but that doesn’t change if a different person edits.
    I’d suggest a feature request, or looking into a more advanced workflow tool like BetterWorkflow to see if it offers a solution.
  • #3 / May 14, 2012 4:00am
    Jabbler
    Most of my data is being edited/ inserted through SAFECRACKER so BetterWorkflow is not able to fulfill my requirement. I guess I will open a feature request :( but the chances of getting it into the dev’s to-do list is slim.
  • #4 / May 14, 2012 6:15am
    Jabbler
    I found a workaround using the Query Module, not sure about the performance impact tho. Here for your reference:
    {exp:query sql="SELECT exp_entry_versioning.entry_id, exp_entry_versioning.author_id, exp_entry_versioning.version_date, exp_members.screen_name AS last_edit_by
         FROM exp_entry_versioning INNER JOIN exp_members
         ON exp_entry_versioning.author_id = exp_members.member_id
         WHERE exp_entry_versioning.entry_id = {entry_id}
         ORDER BY exp_entry_versioning.version_date DESC LIMIT 1"}
            {last_edit_by}
    {/exp:query}
  • #5 / May 14, 2012 10:26am
    Shane Eckert
    Hey Jabbler,
    I am glad to see that Mike was able to offer a suggestion here and I am glad to see that you found a solution that works for you. Nice.
    If you need anything else, please just let us know by opening a new thread.
