Last night we upgraded EE to 2.5, and we’ve noticed that our member module seems to be non-functional; requests for mydomain.com/index.php/member/login are met with an error stating that the page is not found. Anyone else had this problem?
May 10, 2012 11:44am
Subscribe [1]#1 / May 10, 2012 11:44am
#2 / May 10, 2012 12:13pm
Update: I’ve got our member system working with our ‘default’ set of theme templates. For some reason, when I switch back to the theme group we had before, the tags don’t seem to be parsing. Attached is a screenshot of what I mean. Have these tags been deprecated?
#3 / May 10, 2012 12:29pm
Update 2: It seems that the problem is in Agile Records’ template tags, which refuse to parse. Switching to Default fixes everything.
#4 / May 11, 2012 10:48am
Hi rblitadmin,
Did you make sure to update /themes along with your update to 2.5?
Are you using Agile for any other areas of the site?
#5 / May 11, 2012 10:53am
Yes, I made sure to update /themes, and no, we’re not using Agile anywhere else on our site.
#6 / May 15, 2012 4:38pm
Hi rblitadmin,
Can you post the template code that is giving you problems?
I would like to compare it against the version of that template shipped with 2.5
There may have been some updates to Agile that somehow weren’t applied.
#7 / May 15, 2012 4:42pm
I’ve found someone else who had a very similar problem, with similar symptoms: http://ellislab.com/forums/viewthread/150568/
What I had thought were confusing and un-documented theme tags now seem to be global variables that are not being defined.
I should amend my problem description, it is now clear to me that we were not using Agile Records before upgrading, but a different theme group that I have now restored. My problems are solved for the moment, but I am still confused as to why Agile Records, as shipped, does not function. Is there a default set of global variables that a previous developer may have deleted, which are required for Agile Records to render properly?
#8 / May 18, 2012 5:56pm
Hi rblitadmin,
Agile Records is an optional part of the initial installation process of ExpressionEngine 2.
That’s possible, since Agile installs some Global Variables, and they truly are “global” and can be used by any templates or themes in your ExpressionEngine install.
