Problems setting up second site with MSM
May 05, 2012 6:47pm
  • #1 / May 05, 2012 6:47pm
    ahattar
    I have created a second site with MSM following the instructions, but can’t get past this error:
    Your system folder path does not appear to be set correctly. Please open the following file and correct this: index.php
    Folder structure is as follows:
    |── site1 = domain.com (/httpdocs/ee/)
      ├── admin.php
      ├── index.php
      ├── images
      ├── system
      └── themes
    └── site2 = subdomain.domain.com (/httpdocs/site2/)
      ├── admin.php
      └── index.php
    admin.php & index.php for site2 have been updated:
    $system_path = ‘../ee/system’;
    I’ve also tried the full path with no luck.
    Any suggestions?
  • #2 / May 07, 2012 12:37pm
    Dan Decker
    Hi ahattar,
    Thanks for your question!
    Indeed, I think the path may be at issue here. Since site 1 and site 2 are at the same level, you only need one leading “.”
    Try this:
    $system_path = './ee/system';
    The “.” essentially means “go up one level” - so “go up one level and then go into /ee/system”
    Let me know if you have any questions!
  • #3 / May 12, 2012 6:24pm
    sandyyu
    Tried ‘./ee/system’ and no luck. :(
    I thought it might be the php setting for open_basedir, but it’s been updated to “none” by adding a vhosts.conf to the subdomain folder (this is hosted on Media Temple DV 4.0) and I still get the same error (Your system folder path does not appear to be set correctly. Please open the following file and correct this: index.php)
    Any other suggestions that I could try?
  • #4 / May 16, 2012 12:08am
    sandyyu
    This is hosted on MediaTemple DV4, Plesk 10.4.4—
    I updated the file structure as follows:
    |── site1 = domain.com (/var/www/vhosts/domain.com/httpdocs/ee/)
      ├── admin.php
      ├── index.php
      ├── images
      ├── system
      └── themes
    └── site2 = subdomain.domain.com (/var/www/vhosts/domain.com/httpdocs/ee/site2)
      ├── admin.php
      └── index.php
    site2/index.php is set up with system path:
    $system_path = ‘./system’;
    I tried using Plesk 10.4.4 to set the subdomain open_basedir value to none, but that didn’t work. So, I tried manually setting the value to:
    /var/www/vhosts/domain.com/httpdocs/ee/site2/:/tmp/:/var/www/vhosts/domain.com/httpdocs/
    Still no luck with getting the second site working with MSM. Please help.
  • #5 / May 16, 2012 3:49pm
    Dan Decker
    Hi sandyyu,
    I’m sorry for your frustration.
    Based on your description, everything is set properly. The only thing to check is that there isn’t a version mis-match between ExpressionEngine and MSM. What version of each are you using?
    You may need to contact (mt) support for guidance on the open_basedir setting.
    What do you see when you visit your main site?
    What are the contents of /system/expressionengine/config/config.php ?
  • #6 / May 16, 2012 8:32pm
    sandyyu
    Hi Dan -
    Thanks for your help. 😊
    EE:  v2.4.0 - Build: date 20120123
    MSM Version: 2.1.2 Build: 20120123
    What specific values should I send you for config.php?
    Sandy
  • #7 / May 17, 2012 11:10pm
    sandyyu
    Ok, got past the above issue…
    Now, when I use MSM to switch to admin the 2nd site, it’s trying to point to a CSS location that’s not correct.
    Do I update /expressionengine/config/config.php with the right values? Will that impact the first site if I do so?
  • #8 / May 21, 2012 4:48pm
    Dan Decker
    Hi sandyyu,
    Be careful with /system/expressionengine/config/config.php - those values will be applied to ALL MSM sites.
    Your config.php should look similar to this:
    //CONFIG//
    $config['cp_url'] = "http://engine.dev/admin.php";
    $config['doc_url'] = "http://ellislab.com/expressionengine/user-guide/";
    $config['is_system_on'] = "y";
    $config['allow_extensions'] = "y";
    $config['site_label'] = "Site Name";
    $config['cookie_prefix'] = "";
    $config['multiple_sites_enabled'] = "y";
    In addition, all MSM sites should point to the main site for:
    “URL to your “themes” folder”
    “Theme Folder Path”
    Under Admin-> General Configuration
    Can you check that for me for each site as well?
