Experiencing a somewhat odd issue. I could fix this with a conditional in the template I assume, but I feel like I shouldn’t have to.
Anyway, I built the website for an online literary journal that went live in February - http://baltimorereview.org
This was my first dive into EE, and I’m super happy with it. The journal releases a new issue every season. I have it set up so that each issue is a new channel and each entry can be categorized by its type (poetry, fiction, etc.)
Today, I just made the spring issue live and noticed when making a sitemap that it was producing links to the Winter 2012 contributors under the Spring 2012 issue.
For example - rather than:
http://baltimorereview.org/index.php/winter_2012/contributor/devin-murphy (CORRECT)
I was getting:
http://baltimorereview.org/index.php/spring_2012/contributor/devin-murphy (WRONG)
I figured this was just an issue with the sitemap generator, but when I tried the link, it worked. Shouldn’t this link not work? The entry was only entered in the one channel. Thanks for your help!
