Autocomplete in Eclipse for Codeigniter 2
April 27, 2012 3:57am
  • #1 / Apr 27, 2012 3:57am
    mah30
    I found this article about Eclipse autocomplete for Codeigniter 2 & it worked 😊
    autocomplete in Eclipse for codeigniter 2
    after applying those changes when you type
    $this->
    within a function Eclipse suggests all the included classes & methods e.g load
    & if you choose
    $this->load->
    it suggests all the methods of the “load” class
    e.g view ... & preview its parameters 😉
  • #2 / Apr 27, 2012 4:08am
    vrencianz
    Good trick. Thx!
  • #3 / May 04, 2012 1:41am
    vrencianz
    Just an additional observation.
    More autocompletion is possible.  If you want to have auto-completion on the dbforge class for example, just add (as the tutorial says):
      * @var CI_DB_forge
     var $dbforge;
    to the core Controller and Model classes.
