url whit -1
April 24, 2012 1:00pm
  • #1 / Apr 24, 2012 1:00pm
    Federacafe
    hi i have a bug
    when i push the botton update in any post, the ee change the field (Structure URI) that adding a ” -1 “
  • #2 / Apr 25, 2012 12:26pm
    Dan Decker
    Hi Federacafe,
    Thank you for posting to the forums!
    Are you using Structure? Do you have another entry with the same title?
    ExpressionEngine will append the “-1” (or “-2”) and so on, in order to avoid conflicts.
    What you are seeing is the intended behavior.
  • #3 / Apr 25, 2012 6:45pm
    Federacafe
    hi Dan
    yes, I use Structure and the EE user doesn’t use similar names frecuently.
    This problem has showed only 2 weeks ago, and this happend when somebody tries to update some post.
    thx a lot.
  • #4 / Apr 26, 2012 4:50pm
    Dan Decker
    Hi Federacafe,
    I’m afraid since this is directly affecting an aspect of Structure, you will need to contact them for support.
