For some reason, when someone posts a link from our site to Facebook, the url gets set as the name of the article and the description defaults to our default description for the site, so I’m adding open graph meta tags.
I saw I could use embed:title} and {site_name}, but now I need a variable to pull an excerpt of the article itself. Is there such a variable/tag?
Also, I see the main EE doesn’t look like it’s using OGM tags and FB links their site just fine. I’m curious if anyone can shed some light on why it works fine on the main EE site without the tags?
