Hi
I have just installed MSM. When I try and create a new site if I duplicate all channels and channel data I get the below error message
A Database Error Occurred
Error Number: 1048
Column 'entry_id' cannot be null
INSERT INTO `exp_channel_data` (`entry_id`, `site_id`, `channel_id`, `field_id_1`, `field_ft_1`, `field_id_2`, `field_ft_2`, `field_id_3`, `field_ft_3`, `field_id_4`, `field_ft_4`, `field_id_7`, `field_ft_7`, `field_id_8`, `field_ft_8`, `field_id_9`, `field_ft_9`, `field_id_10`, `field_ft_10`, `field_id_11`, `field_ft_11`, `field_id_12`, `field_ft_12`, `field_id_13`, `field_ft_13`, `field_id_14`, `field_ft_14`, `field_id_15`, `field_ft_15`, `field_id_16`, `field_ft_16`, `field_id_17`, `field_ft_17`, `field_id_18`, `field_ft_18`, `field_id_19`, `field_ft_19`, `field_id_20`, `field_ft_20`, `field_id_21`, `field_ft_21`, `field_id_22`, `field_ft_22`, `field_id_23`, `field_ft_23`, `field_id_24`, `field_ft_24`, `field_id_25`, `field_ft_25`, `field_id_26`, `field_ft_26`, `field_id_27`, `field_ft_27`, `field_id_28`, `field_ft_28`, `field_id_29`, `field_ft_29`, `field_id_30`, `field_ft_30`, `field_id_31`, `field_ft_31`, `field_id_32`, `field_ft_32`, `field_id_33`, `field_ft_33`, `field_id_34`, `field_ft_34`, `field_id_35`, `field_ft_35`, `field_id_36`, `field_ft_36`, `field_id_37`, `field_ft_37`, `field_id_38`, `field_ft_38`, `field_id_39`, `field_ft_39`, `field_id_40`, `field_ft_40`, `field_id_41`, `field_ft_41`, `field_id_42`, `field_ft_42`, `field_id_43`, `field_ft_43`, `field_id_44`, `field_ft_44`, `field_id_45`, `field_ft_45`, `field_id_46`, `field_ft_46`, `field_id_47`, `field_ft_47`, `field_id_48`, `field_ft_48`, `field_id_49`, `field_ft_49`, `field_id_50`, `field_ft_50`, `field_id_51`, `field_ft_51`, `field_id_52`, `field_ft_52`, `field_id_53`, `field_ft_53`, `field_id_54`, `field_ft_54`, `field_id_55`, `field_ft_55`, `field_id_56`, `field_ft_56`, `field_id_57`, `field_ft_57`, `field_id_58`, `field_ft_58`, `field_id_59`, `field_ft_59`, `field_id_62`, `field_ft_62`, `field_id_63`, `field_ft_63`, `field_id_64`, `field_ft_64`, `field_id_65`, `field_ft_65`, `field_id_66`, `field_ft_66`, `field_id_67`, `field_ft_67`, `field_id_68`, `field_ft_68`, `field_id_69`, `field_ft_69`, `field_id_70`, `field_ft_70`, `field_id_71`, `field_ft_71`, `field_id_72`, `field_ft_72`, `field_id_73`, `field_ft_73`, `field_id_74`, `field_ft_74`, `field_id_75`, `field_ft_75`, `field_id_76`, `field_ft_76`, `field_id_77`, `field_ft_77`, `field_id_78`, `field_ft_78`, `field_id_79`, `field_ft_79`, `field_id_80`, `field_ft_80`, `field_id_81`, `field_ft_81`, `field_id_82`, `field_ft_82`, `field_id_85`, `field_ft_85`, `field_id_86`, `field_ft_86`, `field_id_87`, `field_ft_87`, `field_id_88`, `field_ft_88`, `field_id_89`, `field_ft_89`, `field_id_90`, `field_ft_90`, `field_id_91`, `field_ft_91`, `field_id_92`, `field_ft_92`, `field_id_93`, `field_ft_93`, `field_id_94`, `field_ft_94`, `field_id_95`, `field_ft_95`, `field_id_96`, `field_ft_96`, `field_id_97`, `field_ft_97`, `field_id_98`, `field_ft_98`) VALUES (NULL, 2, 18, '', NULL, '', NULL, '', NULL, '', NULL, '1', 'none', 'https://ellislab.com/asset/images/team-photo/img-comp-home.png', 'none', '1', 'none', '1', 'none', '', 'none', '', 'xhtml', '', 'xhtml', '', 'none', '', 'none', '', 'xhtml', '', 'none', '', 'none', '', 'xhtml', '', 'xhtml', '', 'xhtml', '', 'none', '', 'xhtml', '', 'none', '', 'xhtml', '', 'none', '', 'xhtml', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'xhtml', '', 'none', '', 'none', '', 'xhtml', '', 'none', '', 'none', '', 'xhtml', '', 'none', '', 'xhtml', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'xhtml', '', 'xhtml', '', 'none', '', 'xhtml', '', 'none', '', 'none', '', 'xhtml', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'xhtml', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none', '', 'none')
Filename: controllers/cp/sites.php
Line Number: 747The site does get created but nothing gets duplicated (Templates/channels/channel data).
If I set up the site and select to duplicate everything expect the channel data it works perfectly. I really need all the channel data though so I don’t have to re-insert it on the new site.
I am using the latest version of EE (2.4.0) and MSM (2.1.2).
Any ideas?
Darren
