Hi guys,
For some strange reason, when I edit an existing channel entry, the default status is set to “-” and the drop down list only has this entry. There are no options for Open or Closed.
Is this a setting somewhere?
The only way I can update the status, is from the entries list and use the check box and tick the ones I want to edit, then edit them. The status is automatically updated to “Open”. I can only close them in the same way.
Anyone seen this before?
Cheers, Mark.
