Sharing pages between templates
March 31, 2012 8:03am
  • #1 / Mar 31, 2012 8:03am
    Nigel-Robertson
    Hi
    v2.4.0 - Build: date 20120123
    I’ve built a site which can be viewed here -
    http://www.modelvillage.ie
    I’m using ‘Pages’ module.
    If you goto - ‘Vistors’ (main nav) and click ‘facilities’ (sub nav)
    that takes you to the Vistors template page ‘facilities’ - fine.
    But if you go to ‘Schools’ and click ‘facilities’ (sub nav) that of
    course takes you to the Visitors template page with Visitors
    sub menu, and you lose the Schools 4 extra entries in the sub nav.
    Basically Schools sub menu shares the Visitors sub menu but has
    4 extra links. Is there a way of going to ‘facilities’ from schools template
    and still seeing the schools sub menu (with the 4 extra entries)?
    Regards
    Nigel
  • #2 / Mar 31, 2012 2:22pm
    Rob Games
    You should be a able to use conditionals and segments to create the menu, e.g:
    {if segment_1 == "schools"}
        Your 4 additional nav items here
    If your client needs to edit the hierarchy or the navigation is quite complex try using an add-on like “structure” or “navee”
