Can’t figure out why the conditional in this code block this isn’t working ...
{exp:channel:categories channel="videos" id="nav_categories" class="nav_categories" show_empty="no"}
<a href="http://{path=/videos}class=current_cat">{category_name}</a>
{/exp:channel:categories}I’ve tested and the segment_2 variable is outputting correctly as is the category_id variable ... just not when inside of the conditional ... which *should* work, shouldn’t it?
Any help would be appreciated!
EEv2.4.0 - Build: date 20120123
