This question is related to a resolved thread.
I thought this was solved but I am seeing the same issue (upload file box loads in the bottom left of the page) on another channel that I had not tested previously.
When I open the inspector I see the following errors that are related to html#file_upload_iframe.js (see screen capture).
Uncaught TypeError: Object [object Object] has no method ‘corner’
template_variables.js:6
Uncaught TypeError: Object function (a,c){return new b.fn.init(a,c,f)} has no method ‘widget’
jquery-ui-1.8.2.tabs.min.js:14
Uncaught TypeError: Object [object Object] has no method ‘tabs’
template_variables.js:3
I have removed the Morphine Theme and NSM Override, reuploaded all of the files in the “Themes” directory. I also reset the publish page layout. Any clues?
