I’ve got an issue with MX Google Maps locator not returning results. I have 3 category lists in the search form, this worked perfectly and still does providing I select a category from at least two of the lists. The issue is when I want a ‘catch all’ result that brings back results in a given location and radius. The first category selects from either a primary or secondary listing and for the example I’m working with they’re all primary so that category is always set to primary. The locator is for restaurants and the two remaining lists are for ‘Cuisine’ and ‘best for’ and the categories both have a parent category both named ‘Cuisine’ and ‘best for’ respectively and both are the default selected fields so if these are left unselected it should return a ‘catch all’ result instead it returns no results.
This was working up until a week ago, the only difference being that data has been continually added in that time.
Is there a limit to the amount of data which the plugin or EE can handle? is it a setting? or possibly something I haven’t thought of.
I have set the memory limit in the PHP.ini to 1024M.
There are currently 253 entries in the area I’m testing and 2600 in total in the database with 2200 of them being restaurant entries.
Any help is very much appreciated
