Safecracker, valid_ip validation rule
March 19, 2012 5:07pm
  • #1 / Mar 19, 2012 5:07pm
    Bransin
    http://ellislab.com/expressionengine/user-guide/modules/safecracker/index.html#rules-my-field-name
    Add additional validation rules to your fields. Separate multiple rules with the pipe | character. You may use the native CodeIgniter rules (required, matches, min_length, max_length, exact_length, alpha, alpha_numeric, alpha_dash, numeric, integer, is_natural, is_natural_no_zero, valid_email, valid_emails, valid_ip, valid_base64), and these additional ExpressionEngine-specific rules: valid_ee_date.
    The safecracker documentation mentions that valid_ip can be used as a validation rule. I receive this in error when trying to use valid_ip validation on a field.
    A PHP Error was encountered
    Severity: Notice
    Message: Undefined property: Safecracker_lib::$input
    Filename: libraries/Form_validation.php
    Line Number: 1038
    Fatal error: Call to a member function valid_ip() on a non-object in /system/codeigniter/system/libraries/Form_validation.php on line 1038
    The snippet of code I am using.
    {exp:safecracker site="site1" class="site_form" entry_id="{segment_2}" channel="test" author_only="yes" include_jquery="no" safecracker_head="no" error_handling="inline" rules:your_ip_address="integer|valid_ip"}
    Input inside of safecracker pair tags.
    <label for="your_ip_address">IP Address</label>
     <input type="text" id="your_ip_address" name="your_ip_address" value="{if your_ip_address}{your_ip_address}{if:else}{ip_address}{/if}" maxlength="45" tabindex="3">
     {if error:your_ip_address}<span class="error">{error:your_ip_address}</span>{/if}
  • #2 / Mar 20, 2012 6:35pm
    Sean C. Smith
    Hi Bransin,
    I have replicated your error on my sandbox install and I’ve filed a bug report for you on this issue. I encourage you to comment on that thread in order to keep informed of the status of the fix. I know that doesn’t help you right now, but follow the thread and you’ll be notified of the fix when it’s available.
    Sean
  • #3 / Mar 20, 2012 6:40pm
    Bransin
    Thanks Sean, will do.
  • #4 / Mar 23, 2012 4:37pm
    Shane Eckert
    Hey Bransin,
    I am glad to see that Sean was able to help you out.
    If you need anything else, please let us know by opening a new thread.
