We’ve just upgraded to EE 2.3 and everything works fine EXCEPT when our IP is mapped to our CDN (which we’ve used for years). When mapped to the CDN users can login but then their session ends when they are redirected past the EE login screen.
So, in short, we need to figure out how to let EE 2 keep a session with a user even if the user’s requests change IP addresses, which happens when using a CDN….
The sequence of events seems to be the following.
1. end-user username/password are POST’ed to our login page: http://www.trendhunter.com/
2. the origin server (trendhunter.com/EE2) responds with multiple Set-Cookie headers (such as exp_sessionid, exp_expiration, exp_anon, exp_last_activity, exp_last_visit) (this happens at the EE login page that says you’ve been logged in)
3. the end-user is redirected to http://www.trendhunter.com/community (or any other trend hunter page) where the cookies from step 2 are used in the request.
The problem seems to be that the load balancer/origin is expecting the POST request from step #1 (”/”) and the request from step #3 (”/community”) to originate from the same server IP. That might not happen in a CDN environment since URLs are load balanced across real servers in a pop location. For instance, the resource “/” might be requested from server A and the resource “/community” might be requested from server B. It seems like the exp_sessionid cookie tracks the IP address of the server at login, and if the cookie is reused from a server with a different IP then the cookie is rejected.
We are using cookies right now, and looking for any solution… Thanks!
