EE 2.4 - "Compatible" Matrix 2.2.4 Not working on front end
March 15, 2012 9:19pm
  • #1 / Mar 15, 2012 9:19pm
    Hi Everyone,
    After a 22 line twitter convo with @pixelandtonic, i’ve been directed to you to further troubleshoot this issue with Matrix that shows up in the front-end, NOT the back end. The back end is error-free and functioning.
    On the front end, any page load yields (attached image)
    Went over all the obvious things - like file placement, re uploading, permissions, enabling/disabling, even character set.
    Now, since EE loads the module, I need to know if you can help me fix it or we have to hack EE : / If that even works.
    Please advise, and hopefully we can get this going. I’m not afraid to go into the guts of the system.
  • #2 / Mar 16, 2012 5:31pm
    Dan Decker
    Hi Caroline,
    Would it be too easy to start with the low-hanging fruit?
    The error points to the Matrix extension as the culprit. You say you have verified and re-verified that the files for Matrix are all in the right place. That’s awesome! The simple question is, did you make sure the extension for Matrix is listed under Add-ons->Extensions?
    It’s not gonna be that easy, is it?
    Are you trying to use this to output your Matrix data in a template? Can you share that template with me?
    Are there any other add-ons in use that might have an impact on this?
    I look forward to your reply!
