Installing EE locally first.
March 12, 2012 4:06am
  • #1 / Mar 12, 2012 4:06am
    Hello, I’m new with expression engine, and I just bought my copy.
    Before I create any site, I usually install it locally, prepare the design and then install it on server.
    In installation I have to fill up License Number, the one I got after purchase.
    I wanted to ask if this key is one time use only? and do I have to install EE directly on desired domain?
    or Is it possible to install it on Wamp first & prepare it and then put it online on server?
  • #2 / Mar 12, 2012 5:37am
  • #3 / Mar 12, 2012 6:19am
    Enviromed
    You’ll find this config bootstrap to be of value to you in your project.  Good luck!
    http://ee-garage.com/nsm-config-bootstrap
    Multiple environments: Configure multiple environments including databases and server paths
    Global variables: Set and update early parsed global variables
    Dynamic: Environment loaded based on the URL
  • #4 / Mar 13, 2012 2:18am
    You just saved a lot of my precious time there..
    Thank you. 😊
