Custom member fields: documentation
March 10, 2012 3:27am
  • #1 / Mar 10, 2012 3:27am
    Nico Meijer
    Hi all,
    I’m trying to build a <select>-dropdown based on a custom member field. Here is my question in the “Development and Programming” forum: Creating a <select>.... Of course, I checked the Member Profile Templates ASAP.
    All documentation I can find on this issue is this: Other Member Fields. That’s nice for displaying an existing value, but that’s not what I’m looking for.
    I must be looking in the wrong direction. Any docs on this? Should / could I use SafeCracker?
    Or is it mandatory to use the Member Profile Templates? (I’m no fan of those, since they take me away from my regular template folder, where I have all my embeds etc right at hand.)
    Thanks… Nico
  • #2 / Mar 10, 2012 5:03am
    mark186282
    It looks like you’re using syntax from the Solspace User module for editing a user’s profile - do you have their module installed?
    Here’s the overview of their user profile edit syntax:
    http://www.solspace.com/docs/detail/user_edit_profile/
    Here’s the specific info about custom field syntax:
    http://www.solspace.com/docs/detail/user_edit_profile/#custom_member_field
    We used the user module a LOT - very well constructed.
    For others reading this post, another interesting approach to managing custom fields for members is the zoo visitor module.
    I hope this helps
  • #3 / Mar 10, 2012 8:42am
    Nico Meijer
    My $DEITY, I hadn’t even noticed that that particular module was installed. Aargh. That’s what you get when someone else built the site, documentation is non-existent and you’re on a tight schedule.
    Thanks for pointing me in the right direction, Mark! Higly appreciated.
    Grtz… Nico
  • #4 / Mar 11, 2012 8:05am
    Sean C. Smith
    Hi Nico,
    Solspace User is a very popular module and well supported by the developer. Have you found the answer over at their support forums?
    Sean
  • #5 / Mar 12, 2012 4:28am
    Nico Meijer
    Hi Sean,
    Yes, all is well. Thanks!
    Grtz… Nico
  • #6 / Mar 12, 2012 5:04pm
    Shane Eckert
    Hey Nico,
    Glad to hear all is well.
    Have a great week!
    Cheers!
