Missing Tables | Database Error After Upgrade to 2.4.0
March 06, 2012 11:38am
  • #1 / Mar 06, 2012 11:38am
    Tom_Watney
    Upgraded from 2.0.2PB01 to v2.4.0 - Build: date 20120123 successfully (though the URL of the themes folder had to be manually updated).
    Now if I go to the Publish ยป Edit link it gives me the following error:
    A Database Error Occurred
    Error Number: 1146
    Table ‘******_EE2012.exp_comments’ doesn’t exist
    SELECT `entry_id`, COUNT(*) as count FROM (`exp_comments`) WHERE `entry_id` IN (‘503’, ‘502’, ‘501’, ‘486’, ‘500’, ‘499’, ‘498’, ‘497’, ‘496’, ‘495’, ‘494’, ‘493’, ‘492’, ‘491’, ‘490’, ‘489’, ‘488’, ‘487’, ‘485’, ‘484’, ‘482’, ‘481’, ‘480’, ‘479’, ‘478’, ‘477’, ‘476’, ‘475’, ‘460’, ‘459’, ‘458’, ‘457’, ‘456’, ‘455’, ‘453’, ‘452’, ‘450’, ‘449’, ‘441’, ‘424’, ‘423’, ‘419’, ‘415’, ‘411’, ‘405’, ‘403’, ‘402’, ‘400’, ‘399’, ‘396’) GROUP BY `entry_id`
    Filename: controllers/cp/content_edit.php
    Line Number: 332
  • #2 / Mar 06, 2012 11:43am
    zizther
    Have you checked in your database to see if the table exists, if not it maybe checking your backup copy.
  • #3 / Mar 06, 2012 11:54am
    Tom_Watney
    Sorry, yes I have checked in PHPadmin and it is not there.
  • #4 / Mar 06, 2012 11:58am
    zizther
    Have you got a backup with the table in it, you can always add it back in.
    When i updated it messed me around a little, i had to do a little manual DB work.
  • #5 / Mar 07, 2012 5:17am
    Tom_Watney
    Hi Zizther,
    I’m afraid I don’t have that table in my backup.
    I wasn’t using the comment functionality - would it be possible to just create this table?
    This then opens up other questions - if I’m missing this table, am I missing any others? I currently have 74 tables.
    Many thanks for your support so far.
  • #6 / Mar 07, 2012 5:51am
    zizther
    I guess you could see if the comments module is installed, i have uploaded an sql dump of the 2 comments tables and the full EE 2.4 tables so you can compare.
    It maybe worth trying the importing the comments table and then if that does not work compare you tables with the fresh install dump i did.
    Just make sure: If your table prefix is different from ‘exp’ edit the file before importing it.
    http://www.sendspace.com/file/moul0s
    The table number can change depending if you have any add-ons installed. On a fresh install of 2.4 you should have 76 tables, so you maybe missing the 2 comments tables.
  • #7 / Mar 07, 2012 10:04am
    Tom_Watney
    Hi Zizther,
    The comments module was not installed, which is as it should be.
    I have imported your blank comments tables into my database and it now works.
    Many thanks for the guide through this and your quick responses.
    Tom
  • #8 / Mar 07, 2012 11:57am
    zizther
    No worries, glad it worked!
  • #9 / Mar 07, 2012 12:29pm
    Shane Eckert
    Hello Tom,
    I am sorry to hear you ran into this known Bug.
    I am glad that you are back up and running. If you wish, you can comment on the bug to stay up to date on it’s progress.
