Javascript not working in control panel after upgrade from 2.3.1 to 2.4
March 05, 2012 12:24pm
  • #1 / Mar 05, 2012 12:24pm
    erutan
    Multiple browsers from multiple people’s machines, so it’s not some weird client side thing.  URLs don’t autocomplete + optional sections don’t open in publish, and accessories don’t open in the general control panel, and tabs don’t open in publish.  jQuery is being called when I view source. I’m using a custom theme (nerdery) but tried both corporate and default with the same behaviour.
    Modules installed: Playa, Datagrab, and SEO Lite (all updated to current versions). I also have Textile and TEH installed, and a lot of the P&T Fieldtypes. Using MSM, updated to latest version,
  • #2 / Mar 06, 2012 7:44am
    Tom_Watney
    I had exactly the same problem.
    I tried reinstalling multiple times without success.
    It is probably linked to the URL being incorrect here:
    General Configuration ยป Theme Folder Path
    This thread has a similar issue.
    ../system/index.php?&C=admin_system&M=general_configuration
  • #3 / Mar 06, 2012 12:49pm
    Shane Eckert
    Hello erutan,
    Tom is on the right track with that diagnosis. Can you double check your theme folder path as well as make sure the folder uploaded correctly (all files are there) and that the permissions on the directory are correct.
    I think this will get you back in business.
    Please let us know how it goes. If you need anything else, please just let me know.
  • #4 / Mar 06, 2012 4:25pm
    erutan
    Changing the control panel path and re-uploading the theme directory fixed it.
    Thanks Tom for pointing me in the right direction!
    You can close this thread.
  • #5 / Mar 06, 2012 4:27pm
    Shane Eckert
    Hello erutan,
    That’s awesome! Glad to hear it.
    If you need anything else, just let us know!
