File {url} not working
March 03, 2012 6:48am
  • #1 / Mar 03, 2012 6:48am
    ukhj
    Hi, I have had a look elsewhere and can’t find anything similar to what I’m experiencing. I am trying to use Flowplayer to play FLV files that are uploaded as part of an entry. The trouble is, when I use {url} within the page template I get a warning.
    Here is my code:
    {scene_trailer}
    <a href="http://{url}" class="player"></a>
    {/scene_trailer}
    And then the Flowplayer JavaScript is below this code.
    When I go to the page, I get the following error:
    A PHP Error was encountered
    Severity: Warning
    Message: array_merge() [function.array-merge]: Argument #1 is not an array
    Filename: libraries/Functions.php
    Line Number: 2585
    Can you help me with this? I don’t see why it wouldn’t work.
  • #2 / Mar 04, 2012 8:25am
    Sean C. Smith
    Hi anthonyweston,
    You are probably running into issues as {url} is a member field and already exists as a variable in ExpressionEngine. If you change the name of your custom field to {video_url} does it then work?
    Sean
  • #3 / Mar 04, 2012 8:37am
    ukhj
    I don’t think I understand. My custom field is called scene_trailer and it’s a file field. I am trying to get it’s {url} in my above code. Have I got this wrong? It has worked for other files.
  • #4 / Mar 05, 2012 7:06pm
    Sean C. Smith
    Hi Anthony,
    Now I understand. I just tested this code on my sandbox install and it worked as expected. could you try this on a blank template to see if you get the url working correctly without flowplay on the page.
    Use this code and replace your_channel with the name of your channel.
    {exp:channel:entries channel="your_channel" }
    {scene_trailer}
    <a href="http://{url}" class="player">{url}</a>
    {/scene_trailer}
    Sean
  • #5 / Mar 06, 2012 6:16am
    ukhj
    Thanks for your reply.
    No, it still doesn’t work. I get the following error 4 times:
    Severity: Warning
    Line Number: 2585
  • #6 / Mar 08, 2012 2:45pm
    Dan Decker
    Hi anthonyweston,
    I have some bad news and some good news. Bad news is, this is a bug :-( Good news is we have a solution 😊 !
    If you apply the solution outlined in the bug report, does this behave properly for you?
