Can't switch between MSM sites
March 01, 2012 4:56am
  • #1 / Mar 01, 2012 4:56am
    Embody_Bruce
    This is since upgrading to the latest EE and MSM, all was fine before.
    When I log into Site A I can work fine.
    I then cross over, via the CP drop down, to Site B and can work fine.
    When I try to cross back to Site A, via the CP drop down, I can’t.
    I have checked and ensured that all admin and index files are set up correctly (but then it was working fine before ...)
  • #2 / Mar 01, 2012 10:27am
    RevaCo
    Did definitely upgrade your ‘MSM files’ as well as your main installation? (MSM files are release dependent)
  • #3 / Mar 01, 2012 11:59am
    Embody_Bruce
    Good thinking and thanks – but, yes, I did upgrade those too.
  • #4 / Mar 01, 2012 12:04pm
    RevaCo
    I’m using 2.4.0 with MSM and cannot reproduce that, but that’s not what you want to hear.
    Have you ruled out your web browser by trying another.
    I know that’s a cliche but you’d be surprised how often it works, it’s the web dev equivalent of ‘Have you turned it off and on again.’
  • #5 / Mar 01, 2012 12:20pm
    Embody_Bruce
    Tried that, it’s not the browser.
  • #6 / Mar 01, 2012 12:23pm
    RevaCo
    So when you switch from Site A to Site B the Sites CP drop down ceases to fire?
  • #7 / Mar 01, 2012 12:26pm
    Embody_Bruce
    The drop down is there and Site A is selectable but it doesn’t successfully change the site.
  • #8 / Mar 01, 2012 12:28pm
    RevaCo
    I had something similar on 2.4.0 where WYGWAM was stopping any links on the CP working.
    When I reloaded the page in the address bar by removing anything after /index.php and hitting enter I could navigate again.
  • #9 / Mar 01, 2012 5:00pm
    Shane Eckert
    Hello Embody_Bruce,
    Did you try the latest solution from johnniefp?
    Also, can you check the folder permissions? If you did update and are unable to select the second site, it sounds like file permissions are not quite right.
    Please let me know what you find.
  • #10 / Mar 02, 2012 1:55am
    Embody_Bruce
    Hi Shane. No, johnniefp’s solution didn’t help. And I have checked file permissions related to the upgrade process and they are correct.
  • #11 / Mar 02, 2012 5:26pm
    Dan Decker
    Howdy folks,
    Have a look at this bug report and give the solution a whirl. If that doesn’t set you straight, let us know.
    Cheers!
  • #12 / Mar 03, 2012 1:39am
    Embody_Bruce
    Hi Dan, thanks a million, that worked.
  • #13 / Mar 05, 2012 4:18pm
    Shane Eckert
    Hey Embody_Bruce,
    Well, I am glad Dan was able to help you. Sorry I missed that being a bug.
    Thanks again for posting your question.
