Backup problem
February 28, 2012 8:31am
  • #1 / Feb 28, 2012 8:31am
    Djive
    Hi, i have problems with backing up database with Backup Pro. You can see my question here:http://devot-ee.com/add-ons/support/backup-pro/viewthread/2785
    I contacted the developer and he can’t find why doesn’t it work. He had full access to database and admin and he confirmed my issue.
    He tells me:
    I have done some research though and discovered that CodeIgniter (the framework ExpressionEngine is built on) has a known issue with mixed character sets that could be causing this issue for you.
    Can you tell me if Codeigniter is the problem here?
    Can only Codeigniter be updated in EE installation, i see that CI 2.0.1 is in EE 2.4.0, but CI 2.1.0 is out already.
    I have EE 2.4.0 installed
    PHP Version 5.2.17
    mysql 5.0.92-community
  • #2 / Feb 28, 2012 5:47pm
    Dan Decker
    Hi Djive,
    I would not recommend doing that at all, it would most certainly fail.
    Are you able to grab a backup of your database using any other database tools such as PHPMyAdmin?
  • #3 / Feb 29, 2012 4:01am
    Djive
    Yes i can make backups with PHPMyAdmin, they are ok.
  • #4 / Mar 01, 2012 1:49pm
    Dan Decker
    Hi Djive,
    While I’m sorry to see that Backup Pro isn’t working for you in this instance, I am happy that other backup measures seem to do the trick.
    I invite you to have the developer of Backup Pro file a bug report with us regarding the mixed character sets issue.
