Backup instructions help
February 25, 2012 12:58pm
  • #1 / Feb 25, 2012 12:58pm
    stevo_s
    Hi - I can’t find any decent info in the user guide for best way to back up EE
    Is there a specific set of options that should be clicked to download the DB in phpmySQL?
    Should website be turned off when downloading DB or does it matter?
    etc.,
    Anything else I should know?
  • #2 / Feb 26, 2012 12:20pm
    Dan Decker
    Hi stevo_s,
    Backing up your database on a regular basis is a fantastic idea. Especially before installing new add-ons or updating a site.
    In PHPMyAdmin, select your ExpressionEngine database and click “Export”. Make sure all tables are selected and the option for “SQL” is set. You want both the “Structure” and “Data” boxes checked, and I use “Complete Inserts”. Check “Save as File” and don’t use compression.
    The most important thing is to test it before you trust it. Do that by importing it into a local install and verifying the data.
    As long as no new content is being added at the time you backup, it makes no difference.
  • #3 / Feb 26, 2012 12:20pm
    Sean C. Smith
    Hi stevo_s,
    When backing up my database I typically make sure to check the options of Add DROP TABLE / VIEW / PROCEDURE / FUNCTION / EVENT and Add CREATE PROCEDURE / FUNCTION / EVENT - I have not had any problems with leaving my site running at the time of backup creation.
    There is an add-on Backup Pro which does a great job of running automatic backups.
    Sean
  • #4 / Feb 28, 2012 7:15am
    stevo_s
    Thats great, thanks.
    Maybe this info could be added to the User Guide? Seems like important info.
  • #5 / Feb 28, 2012 7:17pm
    Sean C. Smith
    Stevo_s,
    That’s a good idea and the user guide does have the option for you to add comments at the bottom of the page. I encourage you to leave one.
    Sean
