Dynamic field names
February 22, 2012 1:24pm
Subscribe [4]
  • #1 / Feb 22, 2012 1:24pm
    emccoe
    This should be simple but then again nothing ever is…..
    As field names need to be unique I am trying to concat the channel id to a field name so I can display the correct field name when using a channel tag
    Is it possible to do something like this:
    {exp:channel:entries channel="channelOne|channelTwo|channelThree" limit="3"}
       {extended_{channel_id}}
    The code above simply displays {extended_1} {extended_2}  {extended_2} etc as a string. It’s not parsing it correctly.
    Thanks.
  • #2 / Feb 23, 2012 5:56am
    emccoe
    Can you specify the parse order of a channel tag? It dosen’t seem to have an effect.
  • #3 / Feb 23, 2012 6:16am
    Mark Bowen
    You’ll need to do something like this :
    {exp:channel entries channel="channelOne|channelTwo|channelThree" limit="3"}
    {if channel_short_name == "channelOne"}
    {my_field_in_channel_one}
    {if channel_short_name == "channelTwo"}
    {my_field_in_channel_two}
    …and so on and so forth…
    Documentation link for {channel_short_name} variable
    Hope that helps a bit.
    Best wishes,
    Mark
  • #4 / Feb 23, 2012 7:25am
    emccoe
    Hi Mark,
    Thanks for the response. That was the approach that I was trying to avoid but if it’s the only way then I’ll go with it. Thanks!
  • #5 / Feb 23, 2012 8:28am
    Boyink!
    You’re running into parse order issues, and you can’t dictate EE’s parse order.
    You can do {{segment_2}_field_name} (if you match template group names to channel names this may work) or {{site_short_name}_field_name} in MSM installs.
  • #6 / Feb 23, 2012 3:44pm
    Shane Eckert
    Hello emccoe,
    The parse order is master that must be obeyed! 😊 I have had my fair share of headaches when all I had to do was look at the parse order.
    Is there anything else I can help you with?
