Tell-A-Friend
February 22, 2012 11:22am
  • #1 / Feb 22, 2012 11:22am
    Phoenix First
    I am trying to create “Tell-A-Friend” Forms for various events at our church.  However, when i paste the code that is supplied that I assume should just work as long as the plugins are installed, The form doesn’t have any function at all.
    http://www.phoenixfirst.org/id/tell-a-friend
    I would appreciate any help I can get on this.
  • #2 / Feb 22, 2012 11:55am
    zizther
    What add-on are you using, and have you got the code your using in your template?
  • #3 / Feb 23, 2012 3:13pm
    Shane Eckert
    Hello Phoenix First,
    I am sorry to hear you are running into this hiccup.
    Are you sure the email module is installed? We should not be seeing those tags.
    Can you also paste in your template code as is?
    It’s probably just that the Add-On is not installed as the tags are not being rendered.
    Let me know how that goes.
  • #4 / Feb 24, 2012 11:44am
    Phoenix First
    Theres nowhere to download it from…everywhere i look to try downloading it says it’s included.
  • #5 / Feb 24, 2012 11:59am
    Shane Eckert
    You are correct, it’s included and is listed under modules.
    Please check Add-Ons->Modules and look for Email. Is it installed?
  • #6 / Feb 24, 2012 12:04pm
    Phoenix First
    yes it is
  • #7 / Feb 24, 2012 12:06pm
    Shane Eckert
    Okay, the tell a friend form is a part of that module, so you should have it.
    Can you send me a screenshot of the modules page?
    What version is this? Is this a commercial install?
    Let me know!
  • #8 / Feb 24, 2012 12:12pm
    Phoenix First
    It’s non-commercial version 2.1.1
  • #9 / Feb 24, 2012 8:24pm
    Sean C. Smith
    Phoenix first,
    ExpressionEngine 2.1.1 is quite old at this point. The latest version of ExpressionEngine is 2.4.0 and there have been many bug fixes and improvements since 2.1.1 came out. If possible I’d like you to upgrade to 2.4.0.
    Sean
  • #10 / Feb 27, 2012 10:22am
    Phoenix First
    I will be backing up the site today and hopefully updating tonight.  We’ll see what happens after that.
  • #11 / Feb 27, 2012 6:47pm
    Sean C. Smith
    PHeonix,
    Do keep us posted on this. Want to see you up and running with no problems.
    Sean
  • #12 / Mar 05, 2012 10:42am
    Phoenix First
    Ok.  So i’ve been somewhat hesetant to do this upgrade because I’m not sure I have everything i need.  I have backed up everything (files & database), However, i’m not finding any file called admin.php,  I have set aside all the rest of the files that need to be replaced after the update.  Where would I find admin.php? (sorry, i’m new to this whole ExpressionEngine thing).
  • #13 / Mar 06, 2012 8:42pm
    Sean C. Smith
    Hi Pheonix First,
    admin.php was added in a version after the one you currently have. In this case all you need to do is add admin.php to your site root after opening it up and setting the system path as you have it in index.php.
    You should be good to go on the upgrade at this point. Keep me posted on your progress.
    Sean
  • #14 / May 16, 2012 12:00pm
    Phoenix First
    Was finally able to update our site.  However.. now the login screen doesn’t have any style.. and the top menu links in the control panel once logged in don’t work (no drop down and they are just dead links) the front end of our site appears fine but the control panel seems very broken.
  • #15 / May 18, 2012 4:46pm
    Shane Eckert
    It sounds like your themes may not be working. Can you try uploading the themes folder again or checking the permissions? The themes folder is where you will find images and CSS and such, which sounds like what is going on here.
    Can you check that out and let me know?
