Hi there, I’m having a problem with EE’s backend (v2.3.1 - Build: date 20111017) frequently logging me out. Sometimes when I try to login it just returns straight away to the login page again, sometimes several times before allowing me in. Then it will often logout me out after a minute or two or when I try to submit a change anywhere in the backend - but not always.
The site has very recently been moved from a testing development server to it home in the real world. It didn’t give me this problem before and it was in the same server setup. It’s running on php 5.3.10
The one major thing thing that has changed is that I set it up on Cloudflare at the same time as the move (so I don’t know precisely if it is this that is causing it). I am also in touch with them to see if they have any ideas. I have set up a Cloudflare “page rule” to exclude anything with /admin.php in the url.
The control panel session type is set to cookies and session id although have also tried it on cookies only and cleared my browser’s cookie cache - no different. I have also tried on several different browsers with no joy.
Starting to tear my hair out on this one!!
Also a problem that seems to have come up out of nowhere is the pagination which no longer seems to work - I’ll submit another post about this but thought I should mention incase it’s somehow related.
Thanks, Michael
