Image not displaying in Safecracker
February 07, 2012 4:51pm
  • #1 / Feb 07, 2012 4:51pm
    spcejunk
    Hello,
    I’m having a problem getting a simple edit image info form to work. Actually, the form works just fine, but we’re not able to display the image next to the form. Here’s the template code
    {exp:safecracker channel="photos" return="photos/" entry_id="{segment_3}"}
    <input type="hidden" name="title" id="title" value="{username}">
    {if photo_1 != ""}
    <label for="title_1">Title</label>
    <input name="title_1" id="title_1" value="{photo_1}" type="text">br >
    {photo_1}
     (doesn't work here)
    <label for="caption_1">Caption</label>
    <textarea name="caption_1" id="caption_1" rows="5' type="text">{caption_1}</textarea><br >
    <input type="submit" value="Submit">
    {/exp:safecracker}
    That image tag ends up looking something like this…
    https://ellislab.com/asset/images/pronet-logo/image_name.jpg
    So, the filedir isn’t getting converted before the html ends up in the browser. All other custom fields are just fine. {photo_1} is a Safecracker file field type.
    Any suggestions?
    (EE 2.3.1)
  • #2 / Feb 08, 2012 3:22pm
    Dan Decker
    Hi spcejunk,
    In order to have SafeCracker process some channel field tags, you have to wrap your {exp:safecracker} tags in {exp:channel:entries} tags.
    {exp:channel:entries channel="photos" entry_id="{segment_3}"}
    {exp:safecracker return="photos/"}
    {if photo_1 != ""}
    {photo_1}
     (doesn't work here)
    {/exp:safecracker}
    Without the channel entries tags, SafeCracker outputs the *value* stored in the field and not the parsed output like you are expecting.
    Cheers!
