Entries doesn't save after editing !
February 03, 2012 9:53pm
  • #1 / Feb 03, 2012 9:53pm
    AndreiCurelaru
    I got a strange but serious problem on ee2.4 :
    I’m editing entries from the admin, and when i hit “Save”, the page loads, but nothing change.
    So i can’t work, i can’t edit pages because any change isn’t saving. It just turn around.
    Anybody else had experience that ?
  • #2 / Feb 04, 2012 7:32am
    mark186282
    No, I haven’t had this experience before - but there’s several things we can do to troubleshoot.
    1.  if you create a brand new channel with no fields, can you create and save entries in this testing channel (this is a decent half-split point and will separate the “fields” from the “channel” for troubleshooting purposes) - if it saves okay… we’re probably dealing with one of your custom fields.  If it does not save okay… then it’s a problem with saving the channel entry at its most basic level.
    2.  are there any errors in your control panel log? (Tools => Logs => Control Panel Log)
    3.  If step 1 saves okay, you might then want to start adding fields to your testing channel (one at a time) - and see which one causes it to break… then we’ll have some more information to begin debugging.
    Let us know what you find
  • #3 / Feb 04, 2012 2:44pm
    AndreiCurelaru
    Solved !
    Thanks for your reply.
    There was no errors displayed, but i guess it was because of the ex-nGen fields (it was a big jump from ee1.6 to ee2.4)
    So : New channel, new set of fields, no more errors, it saves.
    Now i got to make EE saving my templates as file locally. Right path, right chmod, no effect.
    Andrei
  • #4 / Feb 04, 2012 3:42pm
    AndreiCurelaru
    Also fixed the local saving as files, i’m on my way for a long coding night.
    If somebody can close this topic he(she) can.
    Andrei
  • #5 / Feb 05, 2012 6:06am
    Sean C. Smith
    Andrei,
    Glad to see you found the solution yourself on this one. Am closing this thread at your request. Feel free to post again when you need more assistance.
    Sean
