Return parameter in forum module login form?
February 01, 2012 3:33pm
  • #1 / Feb 01, 2012 3:33pm
    imagehat
    It doesn’t appear to be possible, but I’m wondering if you can set a return parameter in the forum module login form. E.g. the in the forums themes forum_login/login_form.html template? I’d like to continue using the forum login form but redirect logged in user to a different starting page than the forum home.
    Or is that kind of flexibility only available in a normal template using the {exp:member:login_form} tag?
    thanks!
  • #2 / Feb 02, 2012 7:12pm
    Sean C. Smith
    Hi imagehat,
    I am unable to find any information on that at the moment. I am going to ping one of the devs to give a definitive answer on that for you though.
    Sean
  • #3 / Feb 03, 2012 10:29am
    imagehat
    Thanks Sean. After a little digging in the module code I’m thinking the answer will be no.
    For now I’ve worked around it with a bit of javascript that tweaks the hidden “RET” input to make the client happy, but it would be good to get the definitive answer. (And make a feature request if need be).
  • #4 / Feb 03, 2012 3:21pm
    Ah- indeed, there isn’t a parameter for it.  That said- you could (as an alternative to the JS) just hard code in the RET as a hidden field.  With forms, if the same field is specified twice, only the last one ‘counts’ if you will.
    So:
    {form_declaration}
    <input type="hidden" name="RET" value="http://127.0.0.1:8888/g20/index.php/somewhere_else/" />
    <div class="spacer"> </div>
    That said?  It would make a good feature request.  For almost any form, it’s nice to know you can override the return!
