Control panel HTML output issues - FIXED
January 30, 2012 12:17pm
Subscribe [0]
  • #1 / Jan 30, 2012 12:17pm
    purple-agency
    I’ve having massive issues trying to resolve a problem where the control panel CSS that’s added by Javascript is closing the <head> of the document right near the top of the document, as follows:
    <html lang="en" class="js"><head><style type="text/css">.button a,
    .cp_button a,
    #search form,
    div.contentMenu,
    #mainContent .formArea,
    #navigationTabs .first_level:not(.addTab){border-radius:10px;}
    #navigationTabs .addTab{border-radius:none;}
    #accessoryTabs li,
    .heading{border-top-right-radius:10px;border-top-left-radius:10px;}
    .tableFooter,
    div.pageContents,
    #mainContent #publishForm{border-bottom-right-radius:10px;border-bottom-left-radius:10px;}
    .newTemplate{border-radius:5px;}
    #write_mode_writer{border-radius:15px;}
    .js_hide{}</style></head><body>
     <meta charset="utf-8"/>
     <title>Control Panel Theme | ExpressionEngine</title>
    Note after the closing style tag, the head is closed and body tag is opened.
    This issue is only happening on a staging server, on my local copy, there’s no error.
    The first assumption here is therefore a path issue, but I’ve checked each and every path and they are all correct.
    The second possible cause is a third party module, however, disabled and checked - still got the same issue.
    It should be noted I’ve had this same problem a number of times in the past.
    In firefox, it shows as whitespace at the top of screen.
    Unfortunately, it messes up a number of areas of the control panel and for the life of me, I simply cannot track down what’s causing the issue.
    As this is working on my local copy and as I cannot find any path issues, could it possibly be a file with a corrupt header, or a file with encoding by staging server isn’t keen on?
    I’m using ExpressionEngine 2.3.1 with the following third party addons:
    Matrix
    Better Workflow
    Navee
    DM EECK
    Freeform
    SEO Lite
    MiniMee
    P&T Fieldpack
    reCaptcha
    Fixed. Was using bootstrap which was causing unforseen path issues with themes.
  • #2 / Jan 31, 2012 1:50pm
    Kevin Smith
    Hi purple-agency,
    Glad you were able to find the solution. Let me know if there’s anything else I can do to help!
