I want to require an email for submitting a comment but without displaying that email. Is this possible?
January 19, 2012 10:39pm
Subscribe [3]#1 / Jan 19, 2012 10:39pm
#2 / Jan 20, 2012 6:06am
Hi buridan
You can easily do this, you can place the email field in the comment form, but when displaying the comments, don’t display the users email, so don’t use {email}.
Your comment form can look like this
{exp:comment:form channel=""}
{if logged_out}
<label for="comment_name">Name</label>
<input id="comment_name" name="name" tabindex="5" type="text" value="" />
<label for="comment_email">Email <small>(Will not be shown)</small></label>
<input id="comment_name" name="email" tabindex="6" type="text" value="" />
<label for="comment_mess">Comment</label>
<textarea id="comment_mess" name="comment" tabindex="7" cols="" rows=""></textarea>
{if captcha}
<div id="captcha">
Please enter the word you see in the image below:
{captcha}
<input name="captcha" tabindex="13" type="text" value="" size="20" maxlength="20" />
</div><!-- / #captcha -->
<input tabindex="8" name="submit" type="submit" value="Add Comment" />
{/exp:comment:form}And your list of comments can look like this
<ul>
{exp:comment:entries sort="asc"}
<li>
<div>{name}</div>
<div>{comment_date format="%d%S %M %Y"}</div>
{comment}
</li>
{/exp:comment:entries}
</ul>Obviously these would be placed inside
{exp:channel:entries channel="" limit="1" required="yes" disable="member_data|pagination"}
{/exp:channel:entries}#3 / Jan 20, 2012 12:07pm
Thank you, zizther! I’ll give it a try.
#4 / Jan 20, 2012 8:48pm
Buriden,
Did zizther’s solution work for you? Is there anything else I can assist you with?
Sean
#5 / Jan 21, 2012 2:22pm
I can’t get it to work. Here’s the code I’m using:
<label for="email">Email <small>(Will not be shown)</small>:</label>
<input type="text" id="name" name="email" value="" size="50" />#6 / Jan 24, 2012 1:45pm
Anyone? Please.
#7 / Jan 25, 2012 8:50pm
I see the mistake I made…
zizther, your solution worked great. Thanks again.
#8 / Jan 26, 2012 5:50pm
Buridan,
I’m glad to see that Zizther’s solution worked for you. Is there anything else I can assist you with?
Sean
