Freeform not working using official 'remove index.php' docs
January 19, 2012 5:09am
  • #1 / Jan 19, 2012 5:09am
    karlosb
    Hi Guys,
    I’m having an issue with my freeform template not actually submitting.
    I’ve sourced the problem down to the ‘remove index.php’ htaccess script as supplied
    on the EE Docs here and as shown below:
    <IfModule mod_rewrite.c>
            RewriteEngine On
            # Removes index.php
            # If 404s, "No Input File" or every URL returns the same thing
            # make it /index.php?/$1 above (add the question mark)
    </IfModule>
    I’ve removed this script from htaccess and the Freeform templates works 100% correct.
    Does anyone alse have this issue or a modification for this?
    Many thanks in advance 😊
    Regards
    Karl
    here
  • #2 / Jan 19, 2012 5:50am
    karlosb
    *** Update ***
    I tried the following and commented out the following from the above:
    #RewriteCond %{REQUEST_FILENAME} !-d
    And it now seems to work!
  • #3 / Jan 19, 2012 6:49am
    karlosb
    I’ve got to the bottom of this now:
    I had an exsiting index.html file in the root directory
    (from an original flat HTML Build of my site before updating to ExpressionEngine).
    This was actually causing the issue, and I’ve now removed the index.html.
    All is now working correctly with the Freeform Template. 😊
