I moved my EE setup from one server to another. But now I encouter an error, caused by wrong path settings. The error I get is:
Message:
is_dir() [function.is-dir]: open_basedir restriction in effect. File(/usr/local/WWW/A/b/bspijker/htdocs/themes/) is not within the allowed path(s): (/home/deb49659/:/tmp:/var/tmp:/usr/local/lib/php/)
Filename: libraries/Core.php
Line Number: 183Where are these settings, I can not find them nor in the database nor in any (config) file
