How to use a template on a single page?
January 16, 2012 8:22am
  • #1 / Jan 16, 2012 8:22am
    JamesBrighton
    I have a channel which is used for a number of pieces of content. One of those pieces needs a contact form (im using freeform). Currently what ive done is add the freeform tags straight into the piece of content.
    Im having an issue with the email field not being included in the notify template. According to the freeform support the freeform tags should be added to a template, not into a piece of content.
    Whats the best way to add the freeform tags to a template but only for one page? I could add it to the channel’s template with some conditional PHP that only showed it if it had the url of the page. However I was wondering if there is a cleaner solution?
  • #2 / Jan 16, 2012 9:20am
    Boyink!
  • #3 / Jan 17, 2012 7:27pm
    Sean C. Smith
    Hi James,
    What I would typically do here for a template that needs special content for only one page is do a conditional check based on the url like so:
    {if segment_3 =="foobar"}
      some content here
    You can change segment_3 to segment_2 or whatever url segment you need to check for.
    Of course Mikes solution would work as well.
    Does that help you out?
    Sean.
