Hello, I have created extension and it seems to be working on localhost but I can’t enable it on client website. I press enable and it again displays that it disabled. EE version v2.3.1. Ext code below
class Wiki_comments_ext {
public $settings = array();
public $description = 'Enables comments for wiki module';
public $docs_url = '';
public $name = 'Wiki Comments';
public $settings_exist = 'n';
public $version = '1.0';
public $channel_id = '';
public $entry_id = '';
public $required_by = array('module');
private $EE;
* Constructor
* @param mixed Settings array or empty string if none exist.
public function __construct($settings = '')
$this->EE =& get_instance();
* add_to_content
* @param
* @return
public function add_to_content($obj)
return $obj->return_data ;
private function _wiki_page_exists($url)
return $this->EE->wiki_comments_model->wiki_page_exists($url);
private function _channel_exists()
return $this->EE->wiki_comments_model->channel_exists();
private function _channel_title_exists($url)
$url = $this->_validate_url_title($url);
return $this->EE->wiki_comments_model->channel_title_exists($url);
public function delete_content()
$this->EE->load->model('wiki_comments_model');
$this->EE->wiki_comments_model->delete_content($this->channel_id, $this->EE->config->item('site_id'));
private function _create_wiki_channel()
return $this->EE->wiki_comments_model->create_wiki_channel($data);
private function _create_wiki_channel_title($url)
return $this->EE->wiki_comments_model->create_wiki_channel_title($data);
private function _create_wiki_channel_data()
$this->EE->wiki_comments_model->create_wiki_channel_data($data);
private function _validate_url_title($url_title = '')
$word_separator = $this->EE->config->item('word_separator');
$this->EE->load->helper('url');
// Remove extraneous characters
$url_title = url_title($url_title, $word_separator);
return $url_title;
* Activate Extension
* This function enters the extension into the exp_extensions table
* @return void
public function activate_extension()
// Setup custom settings in this array.
$this->settings = array();
$data = array(
'class' => __CLASS__,
'method' => 'add_to_content',
'hook' => 'wiki_start',
'settings' => serialize($this->settings),
'version' => $this->version,
'enabled' => 'y'
$this->EE->db->insert('extensions', $data);
* Disable Extension
* This method removes information from the exp_extensions table
* @return void
function disable_extension()
$this->EE->db->where('class', __CLASS__);
$this->EE->db->delete('extensions');
* Update Extension
* This function performs any necessary db updates when the extension
* page is visited
* @return mixed void on update / false if none
function update_extension($current = '')
if ($current == '' OR $current == $this->version)
return FALSE;
