Can't find solution for 404 error under template group
January 08, 2012 2:03pm
  • #1 / Jan 08, 2012 2:03pm
    pixelbaker
    I have successfully setup 404 page for root errors. For example, mysite.com/test-nonexist will be redirect to my 404 page mysite.com/four04.
    However I can’t get this working for template group. For example, mysite.com/blog/test-nonexist will bring a 500 error for normal visitors/members, and a Database error for super admin. I use the template blog.group/index to serve blog pages such as mysite.com/blog/first-post.
    FYI my current strict_url setting is false.
    The methods I’ve tried:
    1. Strict URL method. http://ellislab.com/forums/viewreply/870343/
    I turned strict URL method on, and add {if segment_2 != ''}{redirect="404"}{/if} on the very top of blog.group/index template.
    The result is, all my normal pages got redirected to correct 404 pages. So that’s not acceptable.
    I just followed that method blindly but I think judging if segment_2 is blank is not applicable to my case as I do have valid segment_2 available. What I need to is to redirect to 404 when there is no valid url_title.
    2. I tried to add {if no_results} {redirect="404"} {/if} within Channel Tags of blog/index template, under strict_url off or on. Not working. Still 500 or database error.
    Could you give a hand?
  • #2 / Jan 08, 2012 2:11pm
    pixelbaker
    Aha, I got it. {if no_resutls} should work together with require_entry=“yes”.
  • #3 / Jan 09, 2012 8:23pm
    Sean C. Smith
    Hi pixelbaker,
    Yes typically {if no_results}{redirect="404"}{/if} works well. Has this got it working for you now?
    Sean
  • #4 / Jan 09, 2012 11:26pm
    pixelbaker
    Sean, yes, require_entry=“yes” must be added in my case. That’s the only way it works. 😊
  • #5 / Jan 10, 2012 6:32pm
    Sean C. Smith
    Pixelbaker,
    Excellent. Feel free to post again when you need some more help.
    Sean
