Hi
I have recently finally upgraded my EE1.x site to 2.x (mentioning this as this might have something to do with it.)
In my EE setting I had 1 set of formatting buttons at the top and they worked in multiple fields, wherever the cursor was.
Now I have realised that in EE2.x I need to go and enable formatting buttons in about 6 or 7 places before they appear, and I need to have them repeated on every field. I have done so and the buttons appear.
But strangely they don’t work as expected - if I highlight a piece of text then press on the button, the tags appear elsewhere, usually halfway through the selection, but sometimes on another line. It also happens if I just position the cursor say at the end of a line, the tags appear lower down…
See attached images, I select “ACDSEE” then press the bold button and it appears later on the line… I’d expect it to appear around the selected word, or at the very least as the end of the selection where the cursor is - not later on the line.
Now I have no idea what can be causing this but it is making this rather unusable and make me pine for 1.x back, which is silly.
Any pointers?
PS: the edit form is also noticeably slower, I can usually count to 10 between clicking a category and the tick appearing. Maybe it is all related?
